09 Nov 2023 09:21 AM
Is the aerial cable needed to go in the back of my sky q box to watch TV?
09 Nov 2023 09:41 AM - last edited: 09 Nov 2023 10:35 AM
@Guycj wrote:
Thanks for this. Is this true for live TV and for channels such as bbc?
In the back of the sky q box is all I need the power cable and hdmi (and then connect to wifi) and I will be able to watch everything live or on catch up?
No, your Q box needs to be connectect to the Satellite dish without this the box can't function. I think you may have become mixed up with what is required as you mentioned aerial in your original post.
Sky Q boxes are meant to be used with a Satellite dish (not aerial).
An aerial is used for TV/Boxes designed for Freeview (terrestrial) channels.
If you are getting Sky Q installed this will be setup by the engineer as Sky will do all the neccessary work.
09 Nov 2023 09:25 AM
Sky Q boxes don't have an aerial connection, so you don't need it to be connected to Q.
09 Nov 2023 09:27 AM
09 Nov 2023 10:06 AM - last edited: 09 Nov 2023 10:07 AM
Posted by a Superuser, not a Sky employee. Find out moreIf you have an aerial (RF) lead then you can usually plug this straight into your TV and use its tuner.
But no need really...
09 Nov 2023 12:44 PM - last edited: 09 Nov 2023 12:45 PM
Sky Q is a satellite television system with some online functionality, and so the main Q box absolutely requires a cabled connection to a satellite dish with a Q-compatible LNB pointing at the Astra 28.2E satellite cluster.
Q Mini boxes do not have a satellite dish cable connection because they get their live input from the main Q box.
Sky will not knowingly supply Q subscription and hardware to an address without dish access because it just won't work: the non-satellite Sky television product is Sky Stream.
