Discussion topic: Do i have to have a tv connected to the main sky box for it to work
This message was authored by: lizzielou70
I want to reposition my main tv. i can leave the sky box plugged in but it won't be connected to the tv - will sky work if this is the case
Re: Do i have to have a tv connected to the main sky box for it to work
Yes, the main box will operate without a TV connected.
I presume you have miniboxes?   (Remember they don't support UHD if you have a sub)
Avatar for lizzielou70
That's  v helpful thanks. so do i just unplug the tv from the sky box and move the tv - sorry if i sound thick.! and would i need another sky q box on the tv that's no longer linked to the main sky box so i can change chanel's ?
mini boxes i mean not sky q!
Yes, unless there's a long HDMI cable between the existing box and the television set, you'd need both a Q Mini box and the Multiscreen subscription: this is a fairly substantial extra monthly cost.
The main box can only display a picture via HDMI cable.  There's no easy 'wireless' option.
Otherwise you'll need a mini box and multi screen subscription.  This is primarily intended to run multiple screens rather than an 'extender'.
Alternatively, you can pay to have the satellite cables moved.
so if i paid for the subscription. of another multi screen i wouldn't need the hdmi to the the telly and the sky box ?
sorry if i sound thick !
do you know how many tvs you can have off one multi room subscription ?
says online 4. We have a couple on multi room so surely i could just buy another multi room box ? before i move the tv and wall mount it can you confirm ? many thanks liz
Do you currently have a multiscreen subscription?  (And mini box?)
yes. I have just unplugged the hdmi from the tv and left the sky box power on and it drops the sky signal in the other room so I think Im going to have to get their engineer to move the sky box onto a different wall with a tv on it for the £65 charge. As it doesnt seem to work if there is no tv connected to the box ... Then hope the new position of the satalite dish works ! Would you agree. I do have a different tv on an outside wall. Moving the cables to the existing tv isnt an option
