11
This discussion topic has been answered Discussion topic: Disney + keeps on crashing, freezing & cutting out
This message was authored by: valerie.edwards
Struggling to watch anything on Disney + for the last 5 days it keeps on pausing, cutting out & freezing reboot sky Q box & roter, but it returns a few hours later. Not sure what else I can do.
This message was authored by: RAF69 Answer
Re: Disney + keeps on crashing, freezing & cutting out
Hi, I have had the same issue for about six months and solved it yesterday. Go to settings on the SkyQ box, select set up, then audio visual, scroll down to Judder reduction for TV apps. It was set to off on my box I turned it on and I've watched two films and six programs without issue. I hope this works for you.
This message was authored by: Lisa-P1987
Lisa - Sky Tech Team Expert
This message was authored by: iRodders
I have a similar problem. No freezing but it crashes after roughly 2 hours of viewing. The sky Q box doesn't crash.. just Disney.
Avatar for valerie.edwards
I spoke with the help team at Disney+ they told me it's a common issue for Sky Qbox with smart TVs  as I didn't have this problem before I got my new tv. They did suggest that the maybe sky need to update their tech.  I had to open the Disney+ app on my tv rather than on sky Q to watch any shows. Funny enough I watched Disney+ last week on sky Q box & didn't have any issues. My advice would be to keep contacting sky & or Disney's+ if it happen again to support with trouble shooting.
This message was authored by: Bjsimkiss
Some here after only 30mins.
This message was authored by: Shamus1
Does Sky monitor these forums?
I tried what was previously posted but it doe snot help.
Sky and Disney need to talk to each other and ensure that before Sky adds any apps that they make sure that it is working. It is clearly a Sky and Di8sney plus issue as it works fine on the few smart TV's I have tried.
This message was authored by: Henda100
My judder reduction was on, so I'm trying it with it turned off (as suggested in the Q settings) and see if that works. Let's see...
This message was authored by: Ambidextrous+Eel
Switching judder reduction on or off doesn't solve the issue.
Disney + is now unwatchable and has been for the past month.
This message was authored by: MiteBe
Same for me. I also tried dropping the resolution down to HD (from 4K) and it still happens. I'm suspecting the "app" isn't efficient and using too much CPU for the box. It works fine on another smart TV.
Both Sky Q box and the Smart TV in another room are directly cabled. to the router.
This message was authored by: oDaveo
Same problem. Tried everything to stop it nothing works. Splutters, reboots then freezes solid. Had enough now turned it off !!
This message was authored by: TonyP07
This is happening for me too. I've tried the "Judder" change but no joy.
Has anyone actually resolved their issues?
