12
This discussion topic has been answered Discussion topic: Discussion topic: Sky Q Mini connected to Sky Q Box but displaying 'Technical Fault'
This message was authored by: Moisy
Tried on / off and rebooted router  Main Q box and mini box , fault keeps returning picture comes on for 10-20 mins then off and on , says all connections good but displays technical fault over and over , help please
Re: Discussion topic: Sky Q Mini connected to Sky Q Box but displaying 'Technical Fault'
Hi @Moisy
Have you carried out a Network reset on the mini box.
Hi @Moisy
Avatar for Moisy
Yeah tried this it's worked for years no issues but started recently.
Avatar for Moisy
@oldfella , sorry not used this before , have tried all resets etc , the router Q box and mini have never been moved for year it's worked no issues but recently faulty
Avatar for Moisy
@oldfella @All my apps work Netflix bbc iPlayer ITVx no problem
Is this on the mini @Moisy ??
Avatar for Moisy
@oldfella  yeah the apps work on  both Q box and Mini no issues
Hi @Moisy
Have you tried a Reset Settings in the Q box hidden menu.
If this hasn't helped carry out a similar reset settings in the mini hidden menu
Avatar for Moisy
Will get some one to help me with this one 🙈
This message was authored by: Kezandbri
We are having the exact same problem
 Mini box has worked for years now keeps going off and saying technical fault, it is driving me mad. We had tried everything and nothing works We can only watch netflix or amazon on the Mini box now.    Did you resolve your problem.
Avatar for Moisy
No , they tried all sorts waiting for engineer coming out wait time 1 month , won't be paying for my subscription that's for sure
@Moisy I wouldn't recommend not paying your subscription as if you get into arrears Sky can restrict your  account until the full amout outstanding is paid off and this could also impact your credit rating . Instead i'd suggest waiting until the engineer has visited then request a refund from Sky from the time you reported the problem to them until it was fixed.
LG 49SJ 810 V UHD TV
Google Pixel 10 Pro XL mobile
This message was authored by: Jerdeber
Same here. We have 3 mini Q and all are showing technical fault. Like you, they have been working for years hassle free.
