Discussion topic: Discovery + stopping during Australian Open Match Replay (Sky Q).
Message posted on 22 Jan 2025 04:54 PM
Playback occasionally stops with no warning. The only way to recover I have found so far is to press the Home Button on the Remote and go back into the App. Playback then starts just before the point it previously stopped.
I initially thought it was some sort of timeout as it started happening after an hour or so's playback but it just happened 20 minutes into a match.
Am using wired ethernet into the Sky Q so shouldn't be a local network issue.
Message posted on 23 Jan 2025 09:12 AM
Re: Discovery + stopping during Australian Open Match Replay (Sky Q).
Message posted on 24 Jan 2025 11:14 PM
I watched last night's matches off the planner. When I went to look at the App, Disc + seen to have changed the format, they now have chunks of planner recordings under the heading "Animated AO" rather than the itemised matches under the heading of "Featured Matches" that they used to have. The "Animated AO" chunks seem to play OK but are not useful as so have to scratch around to find the match you want, which may be spread over multiple chunks. There are, obviously, fewer matches now as the tournament ends in a couple of days so this chat is becoming somewhat superfluous, not a great presentation though,
Message posted on 25 Jan 2025 11:22 AM
Featured matches are back, I guess that is a time if day thing and they are cleared at some stage. I have just put on the Women's Final, which is in progress. Have selected watch from start and the row of balls is back.
Message posted on 25 Jan 2025 11:28 AM
Fast forwarded 40 minutes to start of play and it ran for 10minues and stopped with a black screen
