Discussion topic: Discovery+ and TNT sports
Message posted on 21 Feb 2026 05:38 PM
I currently get TNT sports via Discovery+ on SkyQ, but pay my broadband supplier BT £23/mth. Will the changes from March affect this arrangement?
Message posted on 21 Feb 2026 05:45 PM
Re: Discovery+ and TNT sports
Hi @mikewestmorland All Sky do is host the application, they have no control over it. Without doubt, HBO Max App will be available so you should be able to continue watching using that. Your contract for TNT Sports is with BT/EE, not Sky.
Message posted on 21 Feb 2026 08:36 PM
@MightyQuinn wrote:Hi @mikewestmorland All Sky do is host the application, they have no control over it. Without doubt, HBO Max App will be available so you should be able to continue watching using that. Your contract for TNT Sports is with BT/EE, not Sky.
I think If you log into the HBO max app using your bt log in you will probably get your sport as you do now though Discovery+ but you will not probably have access to the new entertainment programming that will available for Sky Q Subscribers for free as this will require a Sky log in but that will not give you access to your tnt sport.
Message posted on 21 Feb 2026 10:27 PM
Assuming you also have a standard Sky package for the other channels, you will almost certainly be in a position whereby a Sky login to HBO Max will give you the HBO Max Basic with Ads, whereas your existing login using BT will give you TNT Sports on HBO Max. The problem will be they will almost certainly be different logins, you are paying Sky for one and BT for the other. TNT Sports is moving from Discovery+ to HBO Max.
