Discussion topic: Despite an hours discussion with Sky my mini box will not connect to my Q box. I am a very unhappy
This message was authored by Eisenberg This message was authored by: Eisenberg
No connection between my mini box and Sky Q box despite being on the phone for over an hour. I am a vert unhappy Sky customer
Re: Despite an hours discussion with Sky my mini box will not connect to my Q box. I am a very unha
Hi @Eisenberg
Reboot the mini as above.
