Discussion topic: Deleted shows are disappearing from deleted menu even though i have more than 70% memory left
This message was authored by Ian47 This message was authored by: Ian47
Never used to do this, shows missing are less than month old
Re: Deleted shows are disappearing from deleted menu even though i have more than 70% memory left
hi @Ian47
I iimagine that space used by deleted items is flagged as availble to use and space may be fragmented  use  so even if a small part of a recoding is used it is no longer available for recovery just like on a computer
Thus , as I say, the fact that you have deleted them will mark that space as available to use
If you want to keep the recordings then you may need to recover(undelete)  them sooner
I would imageine most people will recover deleted entries within a day or so of deleting them
Ian47
Well something new is happening coz I've had stuff on there like concerts for up to 2 years an never had this happen before, as I said only 25% was used so loads of space to fill up before it should start deleting the oldest stuff, thanks anyway
This message was authored by Laing1 This message was authored by: Laing1
@Ian47 if it was programmes downloaded from catch up perhaps Skys right have expired  and the programmes have been removed due to this.
This message was authored by PandJ2020 This message was authored by: PandJ2020
If you're concerned about deleted programmes actually being deleted then don't delete them?
(As noted it's likely to be fragmentation over time that's triggered the 'change')
I am just another Sky customer and my views are my own
Ian47
The reason i delete some stuff I wasn't intending to watch for a while is because we have so much on the main planner it was easier to use delete section as a second planner,  anyway thanks for all replies if it sorts itself il let you all know cheers
An interesting use of the deleted folders... 😄
