Discussion topic: Dark pictures on UHD
Message posted on 20 Apr 2024 02:24 PM
Notsure if you can advise me, I have Samsung tv UE43CU8500KXXU, when I watch sky UHD the picture goes dark/Dim. Thx Dean
Message posted on 20 Apr 2024 02:54 PM
Re: Dark pictures on UHD
Hi @Mackemholic
I suspect that this is due to the peak brightness of the TV being too low to get the benefit of HDR content.
If you are set to 2160p 10 bit resolution try it on 2160p 8 bit and see if this any better.
Message posted on 20 Apr 2024 03:14 PM
@Mackemholic If you look at the rtings.com review of this Samsung TV then you will discover this...........
rtings.com/tv/reviews/samsung/cu8000
The HDR brightness is disappointing. It's not bright enough to display HDR content properly. Bright highlights don't stand out, and overall this TV doesn't provide a good HDR experience.
These measurements are after calibrating the HDR white point, with the following settings:
- HDR Picture Mode: Movie
- Brightness: Max
- Contrast: Max
- Color Tone: Warm 2
Message posted on 20 Apr 2024 03:22 PM
@Mackemholic A typical review of this Samsung TV reveals;
- Brightness: Max
- Contrast: Max
Message posted on 21 Apr 2024 06:40 PM - last edited: 21 Apr 2024 06:40 PM
@Mackemholic I had this issue,
Change the resolution to 2160p but when it asks you 10bit or 8bit, use 8 bit and it will resolve it.
Sky Q 2TB v2 Box + 2 Mini Boxes - Brsk BetterNet1000 FTTP, WatchGuard M400 Firewall, Plume Mesh
Sky Signature + Ultimate TV Pack, Sky Sports, Sky Cinema, Sky Kids, TNT Sports, MUTV, LFCTV, Racing TV, Premier Sports, DAZN
Message posted on 22 Apr 2024 08:23 AM - last edited: 22 Apr 2024 08:28 AM
I've recently switched back to 8bit, my TV isn't capable of a decent HDR (Sony) picture via Sky. I've tried all different types of settings and it still looks gloomy and dark. Not ideal, but for the time being I'm happy with UHD.
Message posted on 28 Apr 2024 12:55 AM
- What's your setup? Is your SkyQ box plugged straight into the TV or via an amp?
- Which HDMI cable are you using? A different one to the one supplied by Sky?
- Are you on the latest firmware for the TV? If not, do an update.
- How is HDR when using Filmmaker Mode? Still dull?
Message posted on 28 Apr 2024 01:03 AM
Not sure the technical limitations of this TV are the issue. A lot of HDR broadcast content just uses a HDR wrapper to trigger HDR modes but their brightness rarely goes above 200-300cd/m². Star Wars series on Disney+ are a prime example. The video image should still look fairly bright even though many broadcasts uses this cheat technique.
There are known issues out there with various broadcasts and TVs. A number of iPlayer UHD programmes used to show up unwatchable dull on my TV (LG C8, calibrated). I sent details to the BBC but I've no idea if it was the BBC stream that couldn't navigate my TV or if it was my TV that couldn't deal with the stream.
Message posted on 28 Apr 2024 01:04 AM
Are the Sky HDR programmes duller than Sky SDR programmes?
Message posted on 28 Apr 2024 01:05 AM
Some TV's just can't do 10bit HDR due to hardware limitations within the tv itself, mostly the screen brightness.
Message posted on 28 Apr 2024 02:22 AM
I doubt Sky HDR broadcasts go very bright very often and even then, it's only various small aspects of video images that hit the peak highs of 600-1000 nits. This is even the case in many 4K HDR blu rays. A number of broadcasts/streams, The Mandalorian for example on Disney+ are using fake HDR (using HDR containers to trigger the setting on TVs) and even though this series comes up as Dolby Vision on my LG OLED tv, it doesn't exceed 200 nits for entire episodes. Various scenes still look bright as well as object highlights, but they would on any TV, including @Mackemholic's Samsung UE43CU8500KXXU.
If I were to take a guess, I reckon Sky's HDR programmes don't go above 200-300 nits for 95% of actual broadcasts.
On another note, there are known issues. When iPlayer's His Dark Materials first came out, it was unwatchably dark on my LG OLED tv (which has been calibrated). A Very British Scandal was also the same. I emailed the BBC to let them know and since, they look a lot better but still not perfect.
I have no idea if this is the fault of the TV not handling the HDR image properly OR if it's the fault of the data from BBC, or both. But it's been improved since I and probably many thousands of others told the BBC.
In addition, HDR isn't all about brightness. It has a hugely increased colour palette which would still make content look far more lifelike, so nothing should look dull, even if a TV is only capable of 300 nits. The Mandalorian series doesn't go above 200 nits but it still appears to show a much better colour palette than SDR content so metal, fire, the sun and other known materials/objects etc that SDR has difficulty showing properly do look more realistic.
Message posted on 06 Sep 2024 04:58 PM
This improved things loads for me. Thank you.
Message posted on 05 Sep 2025 12:55 PM
It's Sky equipment problem not your TV.
I have a JVC, a Philips & a Samsung TV's. All are 4K HDR & all display a dark image with too much clolour when watching Sky UHD channels. Sky tell you to change your picture settings but then when you select a none UHD channel all the colours are dull & the brightness is too high.
When playing PS5, PS4 Pro, XBox One X & XBox Series X they all display with good colour & brightness also with 4K UHD resolution on my PC.
I also stream 4K UHD programs & Movies via several apps on all the TV's & they are all great images.
So as we are all only having problems on Sky UHD Channels you can be assured it's Sky's equipment that is at fault.
Unfortunately Sky so far have refused to accept this & are taking no steps to fix it so your only options are to stop paying for UHD & watch in HD (My Choice) or change your Brightness & Colour settings on your TV every time you changed to or from Sky UHD channels.
Message posted on 09 Sep 2025 07:10 PM
I don't think it's just an issue for Sky. My aforementioned issues with iPlayer content was played directly from the TV, not through Sky. Also, I have a few 4K UHD blu rays and they also show very dark compared to the 2K version. It's an issue with the TVs....they seem to be unable to know how to handle all UHD material and some they just get wrong. It's a new technology in a way compared to decades of SDR material and REC. 709.
