Discussion topic: DVB-S v DVB-S2 on SkyQ - should I manually change it, is it better?
This message was authored by: YorkshireSkyQ
Hi all!
I noticed in the engineers menu, my SkyQ box is set to DVB-S and not the newer DVB-S2.
Is there any benefit to changing it to the latter? i.e. quality of image, reliability, speed of data feed etc?
Best regards
This message was authored by: ThePope27
Re: DVB-S v DVB-S2 on SkyQ - should I manually change it, is it better?
@YorkshireSkyQ ,
The only thing that does in the engineers menu is
1. default the manual tuning Transponder to the one set in the engineers menu.
2. It is the signal strength transponder so when you go into settings > status > satellite signal it's the one that's in there,
There is absolutely no benefit at all, the channels are told whether to use DVB-S2 or DVB-S you can't change it,
DVB-S is being phased out in may anyway.
________________________________________________________________________________________
Sky Q 2TB v2 Box + 2 Mini Boxes - Brsk BetterNet1000 FTTP, WatchGuard M400 Firewall, Plume Mesh
Sky Signature + Ultimate TV Pack, Sky Sports, Sky Cinema, Sky Kids, TNT Sports, MUTV, LFCTV, Racing TV, Premier Sports, DAZN
Avatar for YorkshireSkyQ
Thanks, I appreciate the technical answer.
I can change mine on my SkyQ box, it has a tick next to which one is selected....but as you say there is no benefit in changing it...
@YorkshireSkyQ
Where's is the tick in yours ?
If I hit 'Enter' on the DVB-S2 box, it will switch the setting to it.
@YorkshireSkyQ,
Oh yeah you will be able to but no channels will show up unless it's a DVB-S transponder.
hi @YorkshireSkyQ
The settings are used to tune to the test transponder used in the Signal Status
they all need to be set according to the transmission being used - just like they would need to set when tuing into any channels manually
Thanks for the reply @nigea99, much appreciated.
