Discussion topic: Control with a mind of its own
Message posted on 12 Nov 2024 12:56 PM
Control works for channel and volume contol but wont stop if you rewind or fast forward
Message posted on 12 Nov 2024 01:19 PM
Re: Control with a mind of its own
Hi @Cannyannie
First reboot your Q box.
Then
