Discussion topic: Content with not play on Paramount plus
This message was authored by AnthonyHowe This message was authored by: AnthonyHowe
Trying to watch Section 31 from the Paramount Plus app on my Sky Q but it wont play when I select it.
I can play it from the Paramount Plus app on my tablet, and it seems I can even cast it from there to my TV.
Anyone got any ideas?
This message was authored by Mr+Flibbles+86 This message was authored by: Mr+Flibbles+86
Re: Content with not play on Paramount plus
Posted by a Sky employee
AnthonyHowe
Hi,
Can you restart the sky expert chat because it seems to have expired but the issue is still not resolved, despite resetting the Q box, and forcing a software update.
Thanks.
This message was authored by Lisa-P1987 This message was authored by: Lisa-P1987
Lisa - Sky Tech Team Expert
AnthonyHowe
Hi,
The engineer came and swapped the Q box, but it did not fix the problem with Paramount Plus not showing content. The engineer saw the problem but had no clue how to attempt to fix it. He suggested it must be a problem at the Sky server end.
So what do we try next?
AnthonyHowe
Can someone from Sky please initiate the live chat again so I can progress to a resolution?
AnthonyHowe
This issue needs escalating but Sky seem to have lost interest. How do I get assistance when I've tried everything that's been suggested?
This message was authored by Laing1 This message was authored by: Laing1
@AnthonyHowe you could try refreshing the apps in the engineers menu
To enter the engineers menu do the follow
press the home button then scroll down to setting and hi-light
do not press select/enter but press 001 then select this takes you into the engineers menu
scroll down to apps > refresh
AnthonyHowe
Hi @Laing thanks for trying but ive already done all the things you'd normally expect as advised by the Sky support privately. That includes refreshing the apps, logoff the app and login, force box software update, full factory reset, and a box swap. Everything my end has been done so it must be the Sky end, hence I need their tech support.
They've been responsive until now.
This message was authored by TJ54 This message was authored by: TJ54
Hi
Did you get any help in the end?
We have exactly the same issue and done exactly as you have and still have got no where?
Paramount+ support have also been involved (albeit very poor continuity as they operate only by email so far, so each response is someone different) and still no one has a clue.
AnthonyHowe
@TJ54 no response whatsoever from Sky. They've done the usual stuff but now it's got difficult they say nothing. I've given up chasing them as I can cast from the Paramount app to my TV with the same logonid as I use from my Sky Q box.
