Discussion topic: Contact details to book Sky engineer to replace external Sky cable from dish to Sky Q box.
This message was authored by: Martinsutton1
Contact number to book sky engineer.
To replace cable from dish to SkyQ box
Re: Contact details to book Sky engineer to replace external Sky cable from dish to Sky Q box.
@Martinsutton1
Sky may charge you for this type of service. Typically in the region of £65. It may be cheaper and/or quicker to ask a local satellite company to do it.
These are the current methods for customers needing to contact Sky. Some methods will be more appropriate than others depending on the issue you have.
🟡 📞 Call Customer Services by dialling 150 (free) from either a Sky mobile or your Sky Talk landline if you have Sky Broadband. The forum doesn’t allow the display of other numbers but official numbers to Sky from the UK are 03 numbers which are usually inclusive from non Sky phones.
[If your Sky services are restricted due to a missed payment, calling will only result in a request to pay]
All calls will start automated (aka ‘the bot’) which may offer you the online help route or try to send you here to the forum. Stay on the line as long as possible and sometimes saying nothing when asked the reason for the call helps being put in the queue for an agent.
🟡online help via this link
https://www.sky.com/help
🟡Sky Assistant 💬 should also be available via
🟡Social Media You can also get in touch via the messaging services on Facebook or Instagram, (links at the bottom of the forum page).
Note ~ ROI customers If you’re in the ROI make sure the flag in the bottom right of any link is showing the correct flag and change if required. The Sky Ireland phone lines have different operating hours to the UK and are closed over a weekend.
