Discussion topic: Connectivity problems after full fibre upgrade and change of router by Sky
Message posted on 02 Sep 2025 12:16 PM
I'm a 1st time Sky Community user so here goes. We have an ethernet network round our home with Sky Q and max number of miniboxes. We had our broadband line upgraded to full fibre and as part of that Sky engineer came out and replaced our old Draytek router with a Sky brand. Ever siince we've had constant connectivity issues and, TBH, our local installer (not Sky - own business) has let us down re hos availability. I'm wondering whether to go back to scaratch and get Sky to come in and do a fresh install round the house using their technology (so I guess WiFi connection) as if we were a new customer. Any thoughts out there - I'm not very technical!! I note a discussion late last year on similar issue.
Message posted on 02 Sep 2025 12:36 PM
Re: Connectivity problems after full fibre upgrade and change of router by Sky
Is wifi disabled on all the Sky boxes?
Message posted on 02 Sep 2025 01:22 PM
Hi. I tried to reply already but can't see if it worked! Thanks for responding ... how do I check re your question about wifi connection??
Message posted on 02 Sep 2025 01:27 PM
You need to enter the engineer mode on each box and a menu will appear to disable WiFi.
Hover on Settings and hit '0 0 1' and then select to enter it.
Message posted on 02 Sep 2025 01:31 PM
Thanks for helping. I did that on a couple of boxes and it didn't help. Do I need to do it on all of them?? Does that make a difference?
Message posted on 02 Sep 2025 02:51 PM
Yes. They are stupid and don't stick to an ethernet connection otherwise.
Message posted on 02 Sep 2025 03:02 PM
😃👍ok thanks. I'll try that.
Message posted on 03 Sep 2025 09:57 AM
Good morning. Back onto this. I am trying to put all miniboxes into wifi disabled mode, as per yesterday's advice. Frustratingly, I have one box which keeps saying there's no signal and won't allow me to get to the menu, so I can't get to 'Settings' to do the 001 thing. I've tried rebooting the entire system several times but no joy. Any ideas what I can do???? Thanks if so!
Message posted on 03 Sep 2025 11:55 AM
You can usually hit the home button to get the menu up even if the mini can't get to anything
