Discussion topic: Connecting to my router via my sky Q box
Message posted on 01 Mar 2025 03:35 PM
Can't get my skyQ box to connect to my router
Message posted on 01 Mar 2025 03:42 PM
Re: Connecting to my router via my sky Q box
Hi @Jacksw1
