Discussion topic: Connecting the sku box to router
Message posted on 26 Nov 2025 08:43 PM
New router won't connect with my sky q box . I've followed instructions.
Message posted on 26 Nov 2025 09:08 PM
Re: Connecting the sku box to router
Hi @Jojob2
If on 3rd party broadband or your router does not have a reset button, reboot it by disconnecting the power lead for 30 secs and then reconnecting.
Highlight Status and then select Reset on the right hand side. Follow instructions to connect by WiFi to your router. Even if reset is not listed there is still an option to connect by WiFi to Sky or 3rd party router.
If you are on Sky Broadband with the new Sky Max router then you need to connect it as if it is a 3rd party router.
If you are on 3rd party (non Sky or Sky Max ) broadband then you need to enter the SSID and password for the router 2.4 Ghz WiFi band.
