Discussion topic: Connecting skyQ to my internet
Message posted on 01 Oct 2023 11:04 AM
My skyQ box internet connection broke off but I can't seem to get it back my skyQ box won't connect I tried everything.
Message posted on 01 Oct 2023 11:07 AM
Re: Connecting skyQ to my internet
Hi @Lyndar404
Have you carried out a Network reset exactly as follows on your main Q box.
Highlight Status and then select Reset on the right hand side. Follow instructions to connect by WiFi to your router.
Message posted on 01 Oct 2023 02:03 PM
Hi @oldfella I have tried everything to connect my sky to my internet it says connection to broadband ✔️ connection to internet ❌
Everything is connected in my house so it's not my internet provider don't know what else to do I have phoned sky who put me on hold for 2 hours then cut me off .
