Discussion topic: Connecting sky q to new lg smart tv
Message posted on 27 Jun 2024 08:07 PM
Lg auto tuning is not picking up any stations from sky q.
Sky q and lg tv connected via hdmi cable from pink socket on q box go hdmi on TV
What should the settings be on the TV.
Connection is via satellite
Message posted on 27 Jun 2024 08:16 PM
Re: Connecting sky q to new lg smart tv
You don't 'tune' for a HDMI connection,
Just select the appropriate HDMI input - or try using the home/sky button if CEC is enabled.
Message posted on 27 Jun 2024 08:17 PM - last edited: 27 Jun 2024 08:17 PM
@237scalb you need to switch the Sky Q box on the change your TV source to the same HDMI socket you plugged the HDMI lead into so if your lead from the Q box is in HDMI socket 1 then you need to change the TV source to HDMI 1 and you should then see Sky Q you do not need to tune stations that is only for freeview
LG 49SJ 810 V UHD TV
Google Pixel 10 Pro XL mobile
Message posted on 27 Jun 2024 08:18 PM
hi @237scalb
The tuning you refer to is the Smart TV's internal Satellite tuner & is not SKY Q
This would only find any Channels if it was connected directly to an LNB on a Satellite dish (& uses a different type of LNB to SKY Q)
To use SKY Q you need to select the HDMI input that SKY Q is connected to
Message posted on 27 Jun 2024 08:24 PM
Thanks for your answer
Is that the hdmi setting on the tv?
