11
This discussion topic has been answered Discussion topic: Connecting my remote to tv
This message was authored by: Wilmasue
I've followed all steps and connected my remote to my sky box but it won't connect to the TV so I carnt do volume, turn on/off by my sky remote, I've tried typing the model of my TV in and it doesnt find it,
My old remote was connected to the TV so I'm a little co fused into what to do now
Re: Connecting my remote to tv
Hi @Wilmasue
Try just putting the TV brand in (not the model) and use Find it me in the setup.
Hi @Wilmasue
Avatar for Wilmasue
I've also tried that and nothing
Avatar for Wilmasue
I've also tried that and it didn't work
What Brand and Model is your TV @Wilmasue ?
Avatar for Wilmasue
Bush LE-40GCL-A-T
@Wilmasue wrote:
Bush LE-40GCL-A-T
Hi @Wilmasue
Try Vestel TV codes
Failing that there is Other Brand category's
Avatar for Wilmasue
What do you mean? I'm happy to give anything a go but not sure what you mean
Hi @Wilmasue
The suggestions are referring to setting up the remote for your TV.
You have said that Bush brands are not being recognised.
So my post suggests you try Vestel brand in the remote 1 & 3 pairing for your TV.
If this doesnt work there is also Other Brands.  This is also shown in the TV brand list
This message was authored by: Penrhyn2
Helping a neighbour who has just bought a JVC Roku TV model LT-40CR330 , thats not on skys list. Is there another model l can select to get around this or can SKY put it on their list? All replies greetly apprieciated.
@Penrhyn2 have you tried all the JVC  options if none of them work try Vestel
LG 49SJ 810 V UHD TV
Google Pixel 10 Pro XL mobile
Selected JVC and then selectected model no unknown. It then started to go through a lit of up to 28 settings to control the tv from the sky remote, think it worked on 18.
many thanks 👍👍
