Discussion topic: Connecting Wi-Fi to new TV and mini box problems
Message posted on 05 Jun 2024 02:06 PM
My Wi-Fi is not connecting to my new tv problems with my mini box freezing
Message posted on 05 Jun 2024 03:17 PM
Re: Connecting Wi-Fi to new TV and mini box problems
Hi @Augustus3
When you say your WiFi isnot connecting to your new TV; Is this your Television set or your Q Box?
If it is your Television then you need to connect the WiFi in the Television menu.
If the WiFi is not connecting to the Q box then
When the main Q box is connected and fully working then reboot the Q box.
When the main Q box is complete back up running then reboot the mini as above.
