Discussion topic: Connecting Sky box to sky mini hard wired only
Message posted on 18 Nov 2023 11:14 PM
Yes, I am aware that there a loads of discussions on this matter, but I am moving out of parents house and disconnecting the broadband. My parents don't use broadband. I see a lot of comments on other posts about routers and what not, but I just want to make it as simple as possible for my parents (i'll be doing all the work in fixing this) as they are not techinal at all.
There will be no router in the house either. Is it possible to just hard wire the sky q box to the sky mini via a cat 5/6/7/8 cable? The distance is about 5 meters between where the two boxes will be. I have watched a few videos on Youtube but they keep mentioning routers or IP addressess.
If anybody has done this, I would be grateful for your input and how you solved this.
Message posted on 19 Nov 2023 01:17 AM - last edited: 19 Nov 2023 01:18 AM
Re: Connecting Sky box to sky mini hard wired only
That won't be viable long term. They need an internet connection. Q uses it to verify their subscription I believe.
Message posted on 19 Nov 2023 09:19 AM
@SCOBYOBRIEN While the main Sky Q box will work without an internet connection, albeit with limited functionality, ie no Apps, Downloads or Catch Up, I don't believe the Sky Q Mini Box will.
Sky Community Forum SuperUser
Former Sky+HD Beta Tester
Message posted on 19 Nov 2023 10:45 AM - last edited: 19 Nov 2023 10:47 AM
Well, yes, because communication between main Q box and Q Mini uses TCP/IP and so each unit having a viable IP address is essential. Normally that's handled by the router through its DHCP service: I guess in theory it may be possible to hard-set compatible IP addresses on the boxes through their individual network configuration screens, but I don't recall anyone posting to say they had done so successfully.
Message posted on 19 Nov 2023 10:49 AM
Hi @SCOBYOBRIEN
See Sky link on boxes without an Internet connection.
https://www.sky.com/help/articles/features-available-without-broadband
Message posted on 19 Nov 2023 02:54 PM
Thanks for your input. I think we are just going to have to go with eir broadband as they have the homephone with them and get them a bundle deal
Thanks for the reply. Shame that technology has gone this far that you cannot have a stand alone unit with an add on, but understand the reasons why.
