Discussion topic: Connecting Sky Q box to Vodafone router
Message posted on 06 Jan 2025 08:57 PM
Went to Vodafone full fibre today and once I turned on my TV tonight it seems that I have no internet connection. The router has not been changed and was working fine before the new fibre installation. I have tried to reset the network and tried various ways to reconnect the Sky Q box to the router but to no avail. Even have a booster that is provided by Sky previously but still cannot connect. Takes a long time to manually enter the details and have checked and double checked that all SSID network details and password details are correct. All other devices have connected ok to the router it's only Sky Q that doesnt want to connect to the router. I have also tried various types of security and re=entered all details and password. Keeps saying connection unsuccessful please check settings.
Any advice appreciated.
Message posted on 06 Jan 2025 09:04 PM
Re: Connecting Sky Q box to Vodafone router
Hi @Iain31
Sky Q boosters will not connect to 3rd party routers.
On 3rd party broadband and your router does not have a reset button, reboot it by disconnecting the power lead for 30 secs and then reconnecting.
On 3rd party (non Sky ) broadband then you need to enter the SSID and password for the router 2.4 Ghz WiFi band.
Message posted on 06 Jan 2025 09:41 PM
Thanks. I have tried this several times and it doesn't connect. I have entered the ssid network name and password but keeps saying connection unsuccessful please check settings
Message posted on 07 Feb 2025 06:34 PM
I wondered if you had managed to sort this? I have exactly the same issue and have tried all the steps with no success. Everything worked fine before and all of my other devices have connected without issue.
Message posted on 07 Feb 2025 06:42 PM
Sarah, Yes is the short answer. Took nearly two weeks to sort out with calls to sky and Vodafone. It turns out that my router was at fault and was not sending signals out to the sky Q box. Once my router was replaced it was plugged in and I connected straight away. I did have some success plugging a cable in from router to the back of the sky box and this connected straight away which proved it wasn't the sky box. Hope you get sorted.
Message posted on 19 Feb 2025 09:49 AM
Iain I have a sky engineer coming today as I have the same issue which I cannot resolve - sky Q is not compatible with vodafone and settings need to change to ensure compatibility or else I have to go back to sky broadband which nobody wants to do. Any thoughts on how to change the settings?
Message posted on 19 Feb 2025 10:14 AM
Phil,
I also had a sky booster fitted which helped resolve the issue. If you have a sky engineer coming they should be able to sort. I didn't change any settings sorry
Message posted on 19 Feb 2025 12:23 PM
A sky booster? To a Vodafone router? Ok great thx Iain. Wish me luck!
Message posted on 19 Feb 2025 04:46 PM
@Phil1927 wrote:A sky booster? To a Vodafone router? Ok great thx Iain. Wish me luck!
The booster doesn't communicate with your router, it boosts the signal from the main Sky Q to your Sky mini box.
Message posted on 19 Feb 2025 05:41 PM
Sorted. Brilliant service from sky's engineer. Installed a new sky booster connected to the Vodafone router then reset the sky Q box and mini boxes to connect to the new sky booster.
Message posted on 09 Oct 2025 06:33 PM
We were having this problem. Just needed me running up and down stairs like a numpty resetting anything involved in the farrago. (No engineers were injured in the making of this wireless success story) 😁
