26
Discussion topic: Connecting Mini Box via ethernet question.
This message was authored by KScott This message was authored by: KScott
Re: Connecting Mini Box via ethernet question.
Totally agree. I am now using 3 x TP-link PoE access points placed around the house which are actually positioned better than where my mini boxes are to give best coverage throughout property including garden.
Bonus of running cat5 not only stable sky tv but also hardwired smart TVs and now PS5 connected directly to 100GB fibre. 👍😃👍
This message was authored by Chodley This message was authored by: Chodley
100Gb fibre?!
Sorry. Should of said 1000mbs not 100gbs.
TBH even though I pay for 900+MBs I only get near that connected directly to my router. Most the time it's nearer 500mbs such as through tablet or phone. But 20 x faster than what I was getting through sky
This message was authored by MJNew This message was authored by: MJNew
@KScott @Chodley
Thanks both for extremely helpful & detailed explanations.
Our house is also single story converted barn, with good loft crawlspace. As a barn it has some thick walls, but thin(ish) ceilings; just plasterboard insulation & loft boards.
Based on your advice & experience above, the plan would be to run phone line into loft "cabinet" alongside  Sky router and 2 x hubs.
Then for TV  ...
A - connect main Sky Q box to router by WiFi ( should be possible given proximity in property)
B - connect main Sky Q back to unmanaged switch #1 in loft cabinet by cat6
C - connect remaining Sky Minis (WiFi off) to unmanaged switch #1 by cat6
Note: no cat 6 connections direct to Sky router for TV stuff.
Q1 - for Tv setup above. Any recommendations for the unmanaged switch/hub?
Then for extending WiFi  around house & garage ....
D - connect Sky Router to 1 x unmanaged PoE  (?) switch with cat6
E - connect from PoE switch multiple cat6 cables to various points around house / garage for WiFi mesh access points.
Q2 - what type of switch/hub & access points recommended to create mesh network?
Q3 - to save on cat6 cable runs, is it possible to simply connect everything via a single unmanaged switch & connect Sky Minis to mesh network access points by Ethernet (presuming the APs have a spare Ethernet port)??
anything else I've overlooked?
Much appreciated 👍
You seem to of grasped the same concept that I have done.
for unmanaged switch I have 1 x net gear GS308PP8 and 1 x TP-link TL-SG108
sky is all plugged into the TP link one
link cable between the 2 switches
acces points plugged into Netgear using PoE port's.
You can buy a larger switch with more ports but they tend to have fans and can be noisey in a loft space and give off a bit of heat (mother-in-law complained).
access points (APs) are
TP-link AX1800. Very easy to set up.
connect router via cat 5 or 6 cable to switch (not a PoE port). Connect your access points via cat 5or6 to the PoE ports on the switch.
Not sure if minis will work over your new non sky access point mesh network even if your access points have an available port.
(note: the APs I used only have 1 port)
cat 5 is fairly cheap just run the 2 cables one for AP one for sky mini box. If your AP has a spare port you might consider using it to connect your smart tv direct to the network.
it's just a shame that sky minis don't have additional ports.
to be honest you can get tv all working over cables and try to turn on WiFi as a hotspot and see if it works. I only went with my own APs as I may not always be with sky so wanted a stand-alone system.
I would absolutely not assume the Q will behave itself over wifi. I'd use ethernet there too.
This message was authored by Sumartisinx This message was authored by: Sumartisinx
Follow up question: I have a SkyQ box connected via Ethernet 5e to the router. I have Sky mini box in next room connected ?!) via wifi to the Q box. Regular connection problems to the network. Sky Engineer did a tweak which sorted it for 10 days now Sky mini box refuses to connect no matter what resets, power offs etc etc I do. I have metres of Cat5e cable left over from original house installation.
1. Is it ok to use Cat5e to connect mini to main box?
2. should the Ethernet connection be from the Q box to the mini or mini to router, from where it would find and connect to the Sky Q box? Happy to run wire to either, just as easy. Thanks
1. yes
2. router or a switch as the Q only has one ethernet socket so you can't have it connected to both the router and mini
This message was authored by qprfc1 This message was authored by: qprfc1
Hi guys.
Some excellent info so far which helps me with my plan to run an ethernet cable from the sky router to a sky q mini at the opposite end of the house approx 25m away.
A few additional questions pls:
1. Any preference between external cat 5 or 6 cable over say a 50m length (scenic route) outside the house ,performance wise for tv and wifi. (Sky bb ultrafast)
2. As well as tv I hope it will provide a stronger wifi signal to this dead spot?
3. Is it better to run the ethernet cable from the router or main q box?
4. I may eventually run a 2nd cable from the router to another mini. Will this dilute the signal to the initial cable/tv/wifi
Many thanks
Not an expert and did my own fix:
connected Sky mini direct to router using Cat5e about 20m away. Perfect result, no longer dropping out and no problem it connecting to the main Sky Q box. Sorry cant answer the other q's. Good luck.
@ChorleyThanks.,hadn't checked the available sockets on the Sky Q so your answer was spot on., As stated earlier I went router to mini box using 20m of Cat5e Ethernet cable and all working absolutely perfectly. Thanks for bothering to answer👍👏👏
