Discussion topic: Connect remote to bauhn tv? What make works ? Thanks
This message was authored by: Cheryl8406
Set my bauhn tv to my remote previously but cannot remember what make we need to use to pair it? Thanks
Re: Connect remote to bauhn tv? What make works ? Thanks
Hi @Cheryl8406
Try Other brands in the pairing procedure below.
With the Q box on with green led  try completly resetting your Bluetooth remote.
Then make sure that you are pointing your remote at the Q box and press 1 & 3 together until the led flashes and follow onscreen instructions to re- pair.
This message was authored by: Andyj3
Toshiba works
This message was authored by: smithy8282
@Andyj3  Toshiba didn't work for me -  still can't do it.
it worked on the 3rd or 4th Toshiba option.
This message was authored by: LeaB1984
We had this problem and we chose TD systems which linked our remote
@Cheryl8406 This actually worked.    Can't thank you enough for your help saved me almost getting a new tv in the end.
This message was authored by: Kevin120
Td systems worked for me grateful for these chat groups
