Discussion topic: Connect Sky Q box to Sony stereo with Opitcal Cable
Re: Connect Sky Q box to Sony stereo with Opitcal Cable
@NicHelp1 wrote:
Is on right setting have removed the analogue connection too is only optical cable into setero now? Is driving me up the wall gggrrr
In which case all I can suggest is to try another optical cable - I doubt both the TV and SKY Q box are not outputting a signal
As an aside, please may I ask what the make & model of your Stereo is
Avatar for NicHelp1
This message was authored by: NicHelp1
I really appreciate your help, the stereo is a sony micro hi fi component system cmt cp11, is a brand new optical cable?
@NicHelp1
Ah - reading the manual - the optical connection on your Stereo is an output not input
I think you may need to get an optical to analogie converter  (or an HDMI audio extracter) if you want to use your Stereo
Avatar for NicHelp1
Thank you at least not me, is a bit too beyond my remit. Could you explain what may work in a bit more detail please and what goes where! You've been a great help tyvm.
hi @NicHelp1
Look at the following link - you may want to search elsewhere for Optical to RCA converter
You will see it takes an optical input and provides analogue outputs as needed by your Stereo
Note  : This model (and many others require a USB power supply)
Optical to RCA
BTW I have no personal experience of these units and thus cannot give any reference for this or others
Avatar for NicHelp1
  • If I get the convertor do I need any other cables? Just the optical cable? & do I put the optical cable in sky box still and settings the same? Bring back the days when you used to have to get up to turn tv over 🤔 sorry being needy.
The optical cable from the SKY box into the converter then RCA (aka Phono) lead from the converter to your Stereo
(setting on SKY Q set to Normal as before)
Depending on which converter you get you may need a sparate power supply or it may come with one or it may come with a USB power cable needing a suitable outlet / socket or adapter
Avatar for NicHelp1
That's perfect thank you so much, you're a star! I have usb power thingy in back of tv so all good.
Thank you again for all your help and patience.
Avatar for NicHelp1
Nigea, hope ŵell, I got the convertor still not working? Any help?
Ty in advance.
Avatar for NicHelp1
Is working now unplugged everything started again. Ty so much great help, no more muffled tv sound!
hi @NicHelp1
I am really glad you got it working.
I was just wondering what else to try when you made this post 🙂
