Discussion topic: Connect Sky Q box to Sony stereo with Opitcal Cable
Message posted on 05 Dec 2024 01:58 PM
Hi
I used to run my old sky box through the stereo via the red and white stereo cables straight into sky box connected to stereo, the new sky Q box does not have stereo cable ports. My stereo (old Sony) has optical cable can I connect the stereo straight to the sky Q box with optical? If so what audio settings do I need on Sky Q box? The TV has optical cable port but no optical input option on TV sound settings, I am not the most technical person, can someone please help, the sound quality on the is terrible.
Thanks for any help in advance.
Message posted on 06 Dec 2024 10:37 AM
Re: Connect Sky Q box to Sony stereo with Opitcal Cable
Hi there @NicHelp1 , I’ve escalated your post to our Community Messaging team who will invite you to a private chat shortly and help you with this.
Message posted on 06 Dec 2024 10:45 AM
Hi @NicHelp1 You should connect your old stereo system using the optical cable from TV to the stereo system. That way you can liston to both TV and Sky Q box through the stereo. I don't understand why you mention TV optical in? The TV receives the audio in via the HDMI cable with the pictures, which then outputs the audio via optical to the stereo system.
Message posted on 06 Dec 2024 01:23 PM
Hi
Thank you for your response, I have connected the optical cable from TV to stereo but there is not opitcal cable option on TV sound menu, only SPIF, which doesn't work, or HDM ARC? So was going to connect from sky box to stereo as only watch through Sky anyway.
Any further help much appreciated. Many thanks.
Message posted on 06 Dec 2024 01:26 PM
Hi @NicHelp1 SPIF = Optical.
Message posted on 06 Dec 2024 01:28 PM
Ty, I tried that bit still no sound?
Message posted on 06 Dec 2024 01:30 PM
What's the make and model of the television set? Some cannot take audio from an external HDMI source and pass it to their own optical output.
Message posted on 06 Dec 2024 01:35 PM
Thank you I did read that although all have optical port not all have the functionality? It is a bush DLED32HDSC. Is there a converter or something that I can use?
Thank you any help greatly appreciated.
Message posted on 06 Dec 2024 01:44 PM
@NicHelp1 wrote:
Hi
hi @NicHelp1
Not sure why you are not getting sound from your TV but if you only want to listen to SKY TV via your audio system the SKY Q box has an optical output that you can connect to your system
you are likely to need to set this setting to Normal
Home - Settings - Setup - Audio Visual
Digital audio output Optical
Message posted on 06 Dec 2024 02:31 PM
Thank you. Not sure the TV is compatible with optical. If I put optical cable from Q Box to stereo are the settings you gave me in the sky Menu? Ty in advance.
Message posted on 06 Dec 2024 02:34 PM - last edited: 06 Dec 2024 02:35 PM
Yes - navigate as per my post from the main Home page
Message posted on 06 Dec 2024 02:59 PM
Thank you will try those settings as soon as I get home! I might be back 😂
Message posted on 06 Dec 2024 04:32 PM
Hi
I have put optical cable from Sky Q box to stereo, I have put the settings as you advised Digital Audio Output Optical Normal, is not woking?
Message posted on 06 Dec 2024 04:33 PM - last edited: 06 Dec 2024 04:35 PM
@NicHelp1 wrote:
Hi
Are you sure you are selecting the correct input on your Stereo unit
Edit : You may need to check the manual in case it 'doubles up' on inouts and you may need to change a setting or disconnect an analogue connection
Message posted on 06 Dec 2024 04:40 PM
Is on right setting have removed the analogue connection too is only optical cable into setero now? Is driving me up the wall gggrrr
