Discussion topic: Configuring Sky Q in an Ethernet home network to add a TP-Link Deco mesh wifi system
Message posted on 23 Sep 2023 09:36 AM
I have a Sky Q hub connected via an Ethernet switch to an Ethernet network and currently TP-Link WAPs also wired back to the switch to provide whole house wifi coverage. The Sky hub wifi is disabled. I would like to replace the WAPs with a TP-Link Deco mesh wifi system. Has someone done this?
Message posted on 23 Sep 2023 09:52 AM - last edited: 23 Sep 2023 09:55 AM
Re: Configuring Sky Q in an Ethernet home network to add a TP-Link Deco mesh wifi system
No but it shouldn't affect the Sky ethernet connection. Are there minis involved over wifi here somewhere? Edit: no, can't be, you've disabled wifi.
Message posted on 23 Sep 2023 12:23 PM
So each of the Deco boxes is configured as an Access Point and I simply replace the current TP-Link WAPs with the Deco ones and away we go? No changes to the Q Hub.
Message posted on 23 Sep 2023 12:27 PM
Hi @ChrisC2020
Assuming all Q boxes are connected by the Ethernet to your Network and by the same method and all boxes are connected by Ethernet you can then switch off all Q box WiFi.
Start with main Q box and first carry out a Network reset with the Ethernet connected.
Highlight Status and then select Reset on the right hand side. Select connect wired to non Sky Router . Do not carry out any WPS and just wait for the box to connect. It may take a couple of minutes. If it does not connect there is an issue with the Ethernet connection.
As soon as it connects go into the Q box hidden menu and turn off WiFi.
Go to Network to turn off both bands of WiFi. Confirm before exit.
Repeat the network reset on any minis in the Mini Home menu with the Ethernet connected. Again do not do any WPS and just wait for it to connect.
Once it is connected go into the mini hidden menu (same procedure as above) and turn off both bands of WiFi. Confirm before exit.
Message posted on 17 Oct 2023 10:31 AM
In my case:
BT is the ISP
Deco E4 Mesh system, internet connected with an E4 at the router
Main Sky box and Sky Mini BOTH connected to the their E4's via Ethernet
Wifi switched off on both Main Sky and Mini boxes.
Sky Mini box keeps dropping out. Is the above configuration known to work, or are the E4's known to be problematic even when connected to their Sky boxes over Ethernet from their E4's?
Message posted on 14 Jan 2024 10:29 PM
did you find a good solution in the end?
I have been trying to move all the SkyQ to Deco's via wired connections for each.
I've had problems today with the Minis pausing or losing connection.
Message posted on 10 May 2025 10:54 AM
I'm in the process of upgrading my home network as I constantly have issues with connection to Sky Q mini dropping out. It has become unwatchable. I had thought it was down to network congestion and Sky Hub not being a very good router. I've upgraded the router and just using Hub as a modem only (and for Sky Talk to keep landline). I now have a very highly specified Asus RT-BE88U and will be getting a couple of extra Asus WiFi routers to create a mesh. I'm pretty sure network congestion is / was due to network security cameras and NVR. Even taking them out of equation hasn't resolved Sky Q dropping out. I'm hoping creating the mesh will help. I also have Sky WiFi turned off and was relying on wired network. I'm wondering if that might be the issue as although my house has CAT5 I have a horrible feeling it is not CAT5e which means only 100mbps connections. I'm hopeful having a higher performing mesh network will mean that I can connect Sky boxes to Asus APs and then having everything over WiFi will resolve issues. If anyone has thoughts / suggestions please shout!
Message posted on 10 May 2025 08:39 PM - last edited: 10 May 2025 08:42 PM
Perhaps note that a Sky Hub is always a router: it doesn't have a modem mode.
Encountering actual Cat5 ethernet would be unusual: the 5e standard has been around for a quarter of a century. It's possible that you've got Copper Clad Aluminium (CCA) cable though, and that doesn't rate any Cat status, or possibly the cable only has four rather than eight strands, and would then be inherently limited to 100Mbs by autonegotiation.
