Discussion topic: Channels not working and no satelite signal
Message posted on 25 Apr 2025 06:26 PM
A number of channels are not working saying there is no satellite signal this is going on for a number of weeks .
Channels come up as black screen with no satellite signal
Message posted on 25 Apr 2025 06:30 PM
Re: Channels not working and no satelite signal
Is this on sky+hd or sky q?
Message posted on 25 Apr 2025 07:06 PM
If you have Sky Q…
If you’re seeing a “no satellite signal” message check that the connections from the Sky dish going into the back of your Sky Q box are still finger tight. Otherwise it’s very likely a dish misalignment or possibly a failing LNB (on the arm of the dish) so check the troubleshooting on this link
It’s worth noting that:
a) a misalignment is not necessarily something that will be visible to the naked eye and could only affect one or two channels
b) a Sky Q box requires a periodic 'Keep alive' signal that is delivered via the satellite so if that isn’t received the box will close down until the satellite signal is restored.
If you have Sky+…
Sky no longer support Sky+ and Sky+HD. You'll need to employ a local satellite engineer at your own expense to check/repair/replace it.
If you have Sky Protect insurance through Domestic and General Insurance you can call them but a recent post suggested they wouldn't send an engineer - but did offer the customer £65towards arranging one themselves.
The alternative is contacting Sky to upgrade to Sky Q or change to Glass / Stream.
