5
This discussion topic has been answered Discussion topic: Channels not avsilable. Message tgere is a technical fault on this channel... for most channels
This message was authored by: Robert+K
Technical fault message on all channels.
Apps are working
This message was authored by: nolte Answer
Re: Channels not avsilable. Message tgere is a technical fault on this channel... for most channels
See if a Q box reboot clears it.
Wait for the on screen instructions to disappear and the front led to turn Amber. Then wait for 30 secs before you press Home on your Sky Q remote or if this is not working press the standby button on the front of the Q box
It might take 5 minutes for all features to return.
https://www.sky.com/help/articles/there-is-a-technical-fault-with-this-channel
ROI sky Q Customer.
ROI sky Q Customer.
Avatar for Robert+K
That did it. Thanks!
Hi @nolte
Best to credit the Author if you are going to copy and paste ones posts
Hi @nolte
I'm sorry.
It seemed very similar to the advice in the linked article
ROI sky Q Customer.
Avatar for Robert+K
No problem. Re booting worked. Thanks for the advice.
