This discussion topic has been answered Discussion topic: Channels not avsilable. Message tgere is a technical fault on this channel... for most channels
Message posted on 08 Mar 2024 08:11 PM
Technical fault message on all channels.
Apps are working
Message posted on 08 Mar 2024 11:21 PM
See if a Q box reboot clears it.
Wait for the on screen instructions to disappear and the front led to turn Amber. Then wait for 30 secs before you press Home on your Sky Q remote or if this is not working press the standby button on the front of the Q box
It might take 5 minutes for all features to return.
https://www.sky.com/help/articles/there-is-a-technical-fault-with-this-channel
ROI sky Q Customer.
ROI sky Q Customer.
Message posted on 09 Mar 2024 04:26 PM
Re: Channels not avsilable. Message tgere is a technical fault on this channel... for most channels
That did it. Thanks!
Message posted on 09 Mar 2024 04:32 PM
Wait for the on screen instructions to disappear and the front led to turn Amber. Then wait for 30 secs before you press Home on your Sky Q remote or if this is not working press the standby button on the front of the Q boxIt might take 5 minutes for all features to return.
Hi @nolte
Best to credit the Author if you are going to copy and paste ones posts
Message posted on 09 Mar 2024 05:03 PM
@oldfella wrote:
@nolte wrote:See if a Q box reboot clears it.
Hi @nolte
I'm sorry.
It seemed very similar to the advice in the linked article
ROI sky Q Customer.
Message posted on 09 Mar 2024 07:02 PM
No problem. Re booting worked. Thanks for the advice.
