Discussion topic: Channels default on ones i didnt leave them on
Message posted on 07 Feb 2024 11:11 PM
An odd query I know but the last week or so I will turn my sky on standby, normally on sky one, when powering back on the next day it's default to channel 3 which I never watch.
I have 2 mini boxes aswell and each one has the same issue although they are set to defaulted to other odd channels.
Has this happened to anyone else and if so how can I fix it?
Message posted on 08 Feb 2024 05:38 AM
Re: Channels default on ones i didnt leave them on
I've not seen this issue mentioned before.
Try a reboot of the main Sky Q box, then once that’s back up and running do the same with any mini boxes if necessary-
~ press the 🏠 button
By the way - there isn't a Sky One channel.
Message posted on 08 Feb 2024 08:51 AM
Do you have a local burglar who really likes Corrie?
Message posted on 14 Apr 2024 04:58 PM
I have the same issue(?). Recently a mini box always starts up in TNT1. No idea why.
