Discussion topic: Channels 506, 508, 509 no signal
Message posted on 15 Oct 2023 12:09 AM
Hello, I've no signal on these channel's as of 14th October 23. Anyone else have similar issues? All other channels fine.
Message posted on 15 Oct 2023 06:39 AM
Re: Channels 506, 508, 509 no signal
@Cathal+Kavanagh
”No signal” tends to be a message from your TV (in which case check the cables going to the TV). A “no satellite signal” message relates to your Sky box.
If it displays no satellite signal take a look at the troubleshooting here
It may then give you the opportunity to arrange an engineer to check the alignment of your dish. Just to make you aware, if you’re on a communal dish system in the UK you’ll have to contact your landlord or building management company rather than Sky.
Message posted on 15 Oct 2023 08:00 AM
I think we can be certain they're referring to no satellite signal since they've mentioned specific channels that aren't working!
Message posted on 11 Nov 2023 01:50 AM
Hiya - we've also lost 506 - all others, including 508 and 509, are OK
Looks like a disk alignment issue so planning to call Sky re engineer visit
Message posted on 11 Nov 2023 06:13 AM
Your other post has been replied to.
