This discussion topic has been answered Discussion topic: Channels 171 and 173 not working
Message posted on 07 Oct 2025 05:39 PM
Hello, all of my Sky Q channels are working fine except for channels number 171 and 173. I've noticed that there is no channel 172. I have done a reboot of the box and also a reset of the channels. Can anyone suggest something else please?
Message posted on 07 Oct 2025 05:54 PM
Are you having problems with the True Crime and Legend channels (146/147/148) and ITV+1 (203)? They are broadcast on the same frequency. If so it is likely to be a dish alignment problem as mentioned above.
Message posted on 07 Oct 2025 05:45 PM - last edited: 07 Oct 2025 05:45 PM
Re: Channels 171 and 173 not working
@cescaclem wrote:Can anyone suggest something else please?
Give the dish a wiggle.
But seriously, it may be a small misalignment for which you need an engineer to check.
Message posted on 07 Oct 2025 05:50 PM
@cescaclem what error messages do you get when you try to watch 171 or 173 so you know there is currently no channel 172
LG 49SJ 810 V UHD TV
Google Pixel 10 Pro XL mobile
Message posted on 07 Oct 2025 06:15 PM
Thank you so much. I would never have worked out that the other channels mentioned are all broadcast on the same frequency! I can now ask for an engineer with accurate information. You're amazing!
Message posted on 07 Oct 2025 06:17 PM
No channel 172 listed on the TV guide!
