Discussion topic: Channel 5 on Sky Q - on demand
This message was authored by: AndrewtheScot
Want to watch a programme about Edward VII which was on last night on C5.
can't locate it in catch up on TV
hopped onto iPad as it's easier to search, and it shows it at once in "on demand" when I search the TV guide.
can't download it so go back to TV but C5 doesn't show up in the "On Demand" list, My5 isn't in apps, it's not in My5 on the App on TV outside Sky -and you can't search the TV guide on SkyQ in the same way you can on iPad
So how on earth do I find it and watch it on TV? Husband and I both want to watch it so iPad isn't  the answer!
Re: Channel 5 on Sky Q - on demand
@AndrewtheScot wrote:
can't download it
@AndrewtheScot
If this is the program called Edward VII: The Playboy Prince who changed Britain" I get the option to download to my Sky box via the app after selecting the program.
You should also be able to download it to your box via this link:
https://www.sky.com/watch/title/programme/825c971d-7697-484b-9ddd-019ab04269e2/edward-vii-the-playbo...
This message was authored by: best+of+the+best
@AndrewtheScot I typed in ED using the search button on the Sky Q remote
Avatar for AndrewtheScot
Level 2 icon
Hi.
it is that programme, but I only get it under "on demand" on the app and when I select it, it starts playing automatically without any download option. 😢
Level 2 icon
Aha!
only had Sky for 20 years - never used the search button on the remote before (hadn't even realised it was there....l) 🤦‍♀️
that worked and allowed me to download
Every day's a school day - THANK YOU!
