4
This discussion topic has been answered Discussion topic: Channel 4 HD is pixellated. And only this channel thru sky network.
This message was authored by: PETER-HILL13
So, Channel 4HD is really bad due to pixellation. Watching thru Sky Q box.Can't fix it  - please help. All other channels are absolutely fine.
This message was authored by: xenon81 Answer
Re: Channel 4 HD is pixellated. And only this channel thru sky network.
The South West version of Channel 4 is broadcast on the same frequency as:
109 Alibi HD
110 Gold HD
604 Nickelodeon HD
When you get break-up on Channel 4 check if those channels are affected. If they are you will need an engineer visit to check the dish alignment.
Which BBC or ITV region are you in? This helps to work out which version of Channel 4 you are getting as there are a few different ones (for advertising reasons).
In cases like this it is very often a dish alignment issue and more channels will be affected, just not ones you often watch.
Avatar for PETER-HILL13
Southwest. Plymouth area. No other channels are affected.
109 Alibi HD
110 Gold HD
604 Nickelodeon HD
OK. Ta for that.
