28 Aug 2024 11:49 AM
At the moment I have sky + multi room with a second box in my sons bedroom and the main box in the lounge. If I go to sky q is it possible to have the main sky q box in my sons bedroom rather than where the main box is now in the lounge?
my main reason for this is the worry that he would have connection issues with a q mini box.
28 Aug 2024 11:53 AM
Posted by a Superuser, not a Sky employee. Find out more@Grandmandy The main Q box has to have all the cables from the satellite dish connected to it so unless you can get those moved it's probably best to use the mini in the bedroom and leave the main box where it is
28 Aug 2024 01:35 PM
Many thanks. That explains it for me.
28 Aug 2024 02:20 PM
Posted by a Superuser, not a Sky employee. Find out morehi @Grandmandy
You may, also, wish to read some notes I have made for people considering switching from SKY +/HD to SKY Q
29 Aug 2024 07:43 AM
@Sky992bf Just checking my current wiring, both boxes are wired externally direct from the dish. In fact the bedroom box is nearer to the dish than the main box. Would this mean I could therefore have the main Q box in the bedroom without any disruption to the wiring?
29 Aug 2024 07:48 AM - last edited: 29 Aug 2024 07:50 AM
hi @Grandmandy
You can have the main box in either room but there are a couple things to bear in mind.
The main box needs to be able to connect to your router (usually by wifi but could be via ethernet cable).
Only the main box is UHD capable
BTW I hope you have noted the mention I make in my notes regarding recordings being only stored on the main box & shared between boxes
