Discussion topic: Chanel is currently affected by satellite signals
Message posted on 22 May 2025 04:30 PM
satellite signal issue for last 3 weeks
Message posted on 22 May 2025 04:34 PM
Re: Chanel is currently affected by satellite signals
@PJ358
If you’re seeing a “no satellite signal” message check that the connections from the Sky dish going into the back of your Sky Q box are still finger tight. Otherwise it’s very likely a dish misalignment or possibly a failing LNB (on the arm of the dish) so check the troubleshooting on this link
It’s worth noting that:
