Discussion topic: Chanel 105 freezing sky saying nothing they can do all other channels ok
This message was authored by: Douglas21
Channel 105 pixelating and freezing. All other channels ok. Phoned sky reset etc say nothing they can do.
This message was authored by: ozsat
Re: Chanel 105 freezing sky saying nothing they can do all other channels ok
Do you pay a Sky subscription? Or using a free box?
SkyQ Silver bundle (V2 2TB with UHD/HDR + two minis) in Sky region #71 (Oxford) using VirginMedia Gig1 Fibre (1.2Gbps/100Mbps).
This message was authored by: Fergus+MacRoth
Have you tried resetting the box?
My Ch105 is fine, so that immediately hints at it being a hardware/software issue.
FM
Sorry, I see you have.
FM
Avatar for Douglas21
Yes it's only channel 5 think it's problem with that channel signal, I would think fish might need little adjustment Sky say no
Sky subscription
You need to call Sky back for help and hopefully get a different advisor.
If you are paying a subscription they should be offering help.
