Discussion topic: Certain channels are saying no satellite signal
This message was authored by: Jane+Gibbons
Certain channels I.e channel 5 are saying there isn't a signal
Re: Certain channels are saying no satellite signal
@Jane+Gibbons
”No signal” tends to be a message from your TV. A “no satellite signal” message relates to your Sky box. Take a look at the troubleshooting on the appropriate section of this link. .
https://www.sky.com/help/articles/sky-tv-no-satellite-signal
You may then need to contact Sky and arrange for an engineer to check the alignment of your dish.
This message was authored by: Cynthiamanton
+ hd box isnot getting a satelittle signall
Sk + hd box is not getting a satellite signal
Re: + hd box isnot getting a satelittle signall
@Cynthiamanton
Sky don't support maintenance on Sky+ system any more (you've posted on the Sky Q board). You will need to employ a local satellite company to check it or upgrade to Sky Q.,
