Discussion topic: Cant use skyq mini box as wifi booster
This message was authored by Zidered76 This message was authored by: Zidered76
I've gone into settings, setup, network, advanced settings, but only shows ip settings and set manually. No option to turn on WiFi booster. 2.5gz also turned on. Help??
Re: Cant use skyq mini box as wifi booster
hi @Zidered76
The option is only set on the Main box as it applies to all boxes.
It is not present if your network is SKY as then it is on by default to help create the SKY wifi Mesh & cannot be turned off
