This discussion topic has been answered Discussion topic: Cant turn the volume up or down
Message posted on 10 Feb 2024 09:36 AM
Hi can't turn my volume up or down I have pressed hold 13 and 46 and 79 and it said on my TV put in your TV brand and then I done that and then it said test the volume out of 22 and I done it out of 22 and my volume did not go up or down
@tiko
If anybody could tell me some more information that would be could
Thank you
Rosie
Message posted on 10 Feb 2024 09:50 AM
Thank you
Rosie
Hi @Rosie1985
Don't know it what order you have been pressing buttons.
Try completly resetting your Bluetooth remote again.
Thank you
Rosie
Hi @Rosie1985
Message posted on 10 Feb 2024 10:27 AM
Re: Cant turn the volume up or down
Ok thank you
Message posted on 10 Feb 2024 10:30 AM
Does anybody else know
