Discussion topic: Cant turn box on/remote doesnt work
Message posted on 20 Feb 2024 03:12 PM
Hello all,
I got a sky mini box a year ago (our main one is in the living room)
Recently I haven't been able to turn it on. And the remote won't work (I have changed the batteries) if anyone knows what I can do so the box and remote works I'd really appreciate it
Kind regards,
Francesca
Message posted on 20 Feb 2024 03:17 PM
Re: Cant turn box on/remote doesnt work
@Francesca41
After checking the basics, ie; fresh batteries, re-pairing it etc if your Sky Q remote is definitely broken/faulty, if you follow this link it should allow you to do some more troubleshooting and then it’ll send you to a form to request a replacement (apparently this is not available to customers in the ROI).
https://www.sky.com/help/articles/lost-stolen-damaged-sky-q-equipment#get-in-touch
It may be quicker to purchase a new remote from a retailer or larger supermarket. If you do that as well you’ll have a spare.
Message posted on 20 Feb 2024 04:16 PM
@Francesca41 wrote:
Hello all,
Kind regards,
Francesca
Hi @Francesca41
Have you tried pressing the Standby button (Amber led) on the front of the mini box.
If this turns the mini box on
Try completly resetting your mini Bluetooth remote.
Then make sure that you are pointing your remote at the mini box and press 1 & 3 together until the led flashes and follow onscreen instructions to re- pair.
