Discussion topic: Cant install replacement Q box.
This message was authored by: Kevin2179
Replacement skyQ box arrived. Installation procedure followed.
Screen shows 'Accessibility on Sky Q'
Settings button is highlighted. Unable to select. Remote turns box on but nothing else.
Re: Cant install replacement Q box.
@Kevin2179
Sky have suggested the following...
  • Unpair their Sky Q remote from the box by holding 4&6
  • Wait for the remote to flash
  • Then dismiss the information screen "Skip & set up later"
  • Hold 1&3 to repair the remote control
If 4&6 does not allow you to clear the information screen, try holding 7&9 to reset the Sky Q remote then hold 1&3 and follow the on-screen setup journey to allow the remote to control the TV.
▪️I AM NOT A SKY EMPLOYEE (even undercover)▪️
Hi @Kevin2179
Reset your Q box remote by pressing  and holding 7 & 9 together on the remote until it’s led flashes four times.
This will set it to infrared which will work all Q boxes.   However the remote must be pointed directly at the Q box box.
Switch your Q  box back on and you then you should be able to get past the screen
Once you get the Q box working make sure that you are pointing your remote at the Q box and press 1 & 3 together until the remote led flashes and follow onscreen instructions to re- pair.
