Discussion topic: Cant get bb1 hd on sky q nox
Message posted on 08 Oct 2023 07:45 PM
Message posted on 08 Oct 2023 07:56 PM
Re: Cant get bb1 hd on sky q nox
@Teevee1 In the UK it is on 101 on the EPG
What happens when you select the channel?
Message posted on 18 Nov 2023 12:07 PM
That's the channel I'm trying to view just get signal error message. Everything else is ok
Message posted on 18 Nov 2023 12:10 PM - last edited: 18 Nov 2023 12:12 PM
Could be a slight dish alignment issue @Teevee1
This can affect the channels with the weakest reception .
Only way to check for sure is an Engineer visit.
Check out the following link
https://www.sky.com/help/articles/sky-tv-no-satellite-signal-sky-q-standard-help
