Discussion topic: Cant connect my skyQ box to the wifi. Keeps saying wrong password and wont accept it.
Message posted on 14 Jun 2024 04:43 PM
Message posted on 14 Jun 2024 05:02 PM
Re: Cant connect my skyQ box to the wifi. Keeps saying wrong password and wont accept it.
Who is your Broadband supplier @Seadragon1 ??
Message posted on 14 Jun 2024 06:37 PM
Sky
Message posted on 14 Jun 2024 07:12 PM - last edited: 14 Jun 2024 07:14 PM
@Seadragon1 wrote:
Sky
Ok @Seadragon1
That's why it will not accept a password. You need to connect using WPS on sSky Broadband.
On Sky broadband hold the Reset on the back of the router until the power light flashes green (about 10 seconds). Don't unplug or switch off your router while it resets. The power light will go green when it's done.
On Sky Broadband you will be asked to press the WPS button on the Sky router. (Not on the Q box as the Network reset will start the main Q box WPS automatically). Make sure you press the WPS button on the Sky router and not the reset button.
