Discussion topic: Cant connect my 3rd party router to sky q box
This message was authored by: Yog1
Can't connect  my virgin media router to sky q box
Re: Cant connect my 3rd party router to sky q box
Hi @Yog1
Assume you have tried Network Reset found in Q box Home - Settings - Setup - Network.
Highlight Status and then select Reset on the right hand side. Follow instructions to connect by WiFi to your router.
As you are on 3rd party (non Sky ) broadband then you need to enter the SSID and password for the router 2.4 Ghz WiFi band.
Avatar for Yog1
Hi old fella tried that didn't work?
That's the only way to connect it by WiFi @Yog1
Either it is too far away or else there is an issue with the router WiFi range.
Do you have the possibility to connect your Q box to your router by Ethernet cable?
Another option would be to ask Sky for a Q WiFi booster.
Then you could connect this to your router by a (shortish) Ethernet cable.
You could then use WPS to connect your Q box to the booster WiFi.
