Discussion topic: Cant connect Sky Q hub to wifi
This message was authored by: kellyfamily
we had a power outage over night . My Sky Q hub will not connect to wifi and one of our Q boxes comes up completely blank on screen
Re: Cant connect Sky Q hub to wifi
Hi @kellyfamily
Highlight Status and then select Reset on the right hand side. Follow instructions to connect by WiFi to your router. Even if reset is not listed there is still an option to connect by WiFi to Sky or 3rd party router.
If you are on Sky Broadband with the new Sky Max router then you need to connect it as if it is a 3rd party router.
If you are on 3rd party (non Sky ) broadband then you need to enter the SSID and password for the router 2.4 Ghz WiFi band.
If you get your Main Q box connected OK and still have issues with your mini then try rebooting the main Q box and then when this is completely back up and running reboot the mini.
Reboot the mini as above.
If you are on Sky Broadband and the Router is nearer to the mini than the main box then you can try pressing WPS on the router instead of the main Q box. If you do this make sure you press the Sky router WPS button and not the router reset button. If you have the new Sky Max router then you need to connect the WPS to the main Q box.
This message was authored by: rick555
did not understand any
