Discussion topic: Cant Select uhd through Onkyo Receiver
This message was authored by Guyt This message was authored by: Guyt
Hi ,
Just installed a new 86" LG Tv which I am running through my Onkyo TX-NR595 receiver.
The Spec of the amp says HDMI 6 In / 1 Out (4K UltraHD / HDCP 2.2) so I assume it is ok to pass the UHD signal .
Prob is that I get the UH011 error and cant set the box to UHD.
If I connect direct to the same port on the TV misssing the Onkyo, it works fine.
Any suggestions ?
This message was authored by bob1234 This message was authored by: bob1234
Re: Cant Select uhd through Onkyo Receiver
@GuytWithout being able to look at the circuitry it will be effectively a splitter/switch if you have anything else connected to the other outputs that are not the correct HDMI specification it may depending on what it actually does fail.
Have you tried connecting its input to the HDMIarc output on your TV if it has one and see if that works, that might take you a step nearer to finding what the problem is.
Guyt
The Q box is connected directly to the input of the Onkyo ( 7.1) amp and the output of the amp goes direct to the eARC HDMI input on the TV . There is nothing else in the system...this is a basic surround sound setup .
The port on the amp is stated to be HDCP2.2 compliant .The TV clearly is compliant cause it works when I connect direct to it...
hi @Guyt
Can we just check that the lead from SKy Q to the Onkyo is <3m ?
Looking at the Onkyo manual I can't see any reason why it should not work - although I will try looking a bit deeper in case there is a setting needed.
Just out of interest have you tried more than one input on the Onkyo ? If not although unlikely to change anything it might be worth a try
@Guyt
One further thing to check :
Although hiighly unlikely this is the problem, double check the TV settings for the eARC Port to make sure it is set for Deep Color or similar setting (I can't remember the LG specific one) as each HDMI are often set separately
But have you tried connecting the input to the amp to the HDMI arc socket so it works as an output from the TV.
Guyt
OK , sussed it I think.
The LG box was set for 4k deep colour which didnt work when connected through the Onkyo.
When I switched this off, the Sky Q box then immediately let me select UHD in 8 bit mode ..
I now need to see how to set it at 10bit mode ...
This message was authored by simon194 This message was authored by: simon194
I'm not familiar with Onkyo's but a lot of AVR's have a HDMI mode setting in the setup menu which affects how an external HDMI signal is handled.
You will need to have Deep Colour switched on on your LG for it to work in 10-bit mode.
_____________________________________________________
This message was authored by elzzad This message was authored by: elzzad
I have an Onkyo Receiver and I had to switch the HDMI inputs to enhanced mode as described in https://www.onkyo.com/manual/sup/upd/hdmi_4k_onk.pdf
