Discussion topic: Cannot watch sky tv as i have scaffolding blicking signal
Message posted on 03 Aug 2024 04:33 PM
Cannot watch sky tv as i have scaffolding around the house blocking signal ,trued calling sky they cut off the call after 30 mins ! Not happy
Message posted on 03 Aug 2024 04:39 PM
Re: Cannot watch sky tv as i have scaffolding blicking signal
You will have to persevere on the phone if you want to book an engineer to move the dish (as long as there is an alternative spot). Sky normally charge about £65 for this.
Message posted on 03 Aug 2024 04:40 PM - last edited: 03 Aug 2024 04:43 PM
@Steveboreham67 If you have installed scaffolding around your property that has prevented a previously working system from receiving a satellite signal then sky aren't responsible for the loss
You will need to preserve on the phone if you wish to have the dish moved
Message posted on 03 Aug 2024 05:08 PM
My landlord erected the scaffolding, no sign of it being taken down anytime soon ,was told by a riend that sky can provide you with something so you can use wifi to watch the tv
Message posted on 03 Aug 2024 05:13 PM
@Steveboreham67 Sky Q uses satellite only as for WiFi perhaps your friend was referring to Sky go an app which will allow you to watch on mobile devices such as phones laptops pcs, that will be the only way you can watch unless you can get the dish moved
Message posted on 03 Aug 2024 05:46 PM
You'll also need your landlords permission before Sky will potentially move the dish.
Message posted on 04 Aug 2024 11:37 AM
They may have been referring to Sky Stream, but that's a permanent replacement for Q rather than a temporary fix.
