10
This discussion topic has been answered Discussion topic: Cannot link my sky sound box to my new Samsung tv
This message was authored by: McLeanN
My new Samsung tv does not have an optical port therefore cannot connect to my sky soundbox. The soundbox does not support ARC there cannot use HDMI connections. Can anyone suggest a way round this as I reluctant to give my soundbox.
This message was authored by: nigea99 Answer
Re: Cannot link my sky sound box to my new Samsung tv
@mike+simmonds wrote:
Does the Soundbox support full UHD/HDR pass through - if not the optical route may be better
Hi @nigea99
I think the Soundbox does support UHD/HDR pass through
Thanks @mike+simmonds
I was fairly confident it supports UHD but just not sure regarding 12bit (edit : 10bit) HDR
It does seem slightly odd that it would support UHD/HDR pass through which is newer than ARC
As it does I would echo the HDMI from SKY Q to sound box & Soundbox to TV route
@mike+simmonds
Your expertise on connecting a Sky soundbox required here?
hi @McLeanN
As you have posted in SKY Q then for SKY Q sound you can use the optical output from the SKY Q box which obviously means you can;t use it for apps etc. on the TV itself
I do not know if an HDMI to optical converter would work if connected to the ARC port on the TV as it might need an ARC handshake
This message was authored by: mike+simmonds
Hi @McLeanN
 As you have worked out, without an optical port on your TV you are a little limited on what you can do with your Soundbox.
Do you have Sky Q ?
If so - you need 2 HDMI cables. The first one goes out of your Sky Q box and IN to your Soundbox using the black port.
The 2nd HDMI cable then goes OUT of your Soundbox (the Pink port) and in to your TV
So in that way you have your Sky audio going in to your Soundbox and Sky video still reaches your TV.  You might need to turn your TV volume down to Zero to avoid echoes.
Where you have a problem is if you want to use any apps built in to your TV.  Without an optical port you would have to use your TVs own speaker / speakers for internal TV apps*.
*I would mention, I think Optical / HDMI converters exist and are fairly inexpensive, but I haven't never tried one.  If your TV has a spare HDMI port you could try an HDMI / optical converter in there. So - an optical cable out of that converter and in to your Soundbox.  If you decide to try a converter, make sure it's refundable in case it doesn't work as well as you would like.
if you have a look at the link in my signature below - I've written a little article on the Soundbar which might be helpful.
Hope that helps a bit.
Thanks for highlighting this post @lettice   Best wishes
Sky customer since 1989.
Sky Q 2TB main box
LG CX6LA from 2020
Hi @McLeanN
Do you have Sky Q ?
*I would mention, I think Optical / HDMI converters exist and are fairly inexpensive, but I haven't never tried one.  If your TV has a spare HDMI input you could try an HDMI / optical converter in there. So - an optical cable out of that converter and in to your Soundbox.  If you decide to try a converter, make sure it's refundable in case it doesn't work as well as you would like.
@mike+simmonds
Hi @nigea99
Sky Q 2TB main box
LG CX6LA from 2020
Hi @nigea99
My LG is 10 bit HDR and works fine @nigea99
Can't comment on 12 bit but I don't recall ever reading any posts where someone said not.
Sky Q 2TB main box
LG CX6LA from 2020
oops sorry I meant 10 bit HDR !
@nigea99
My guess is that as the Soundbox was designed specifically for Sky Q by Devialet they were asked to save a bit of their production costs by leaving out the ARC as it wasn't essential for use with the Sky box only ?
Sky Q 2TB main box
LG CX6LA from 2020
Avatar for McLeanN
Level 2 icon
That seems to have worked. Many thanks
